System Requirements
Wise Toys will run on any PC running Microsoft Windows 7 or later. If you're running one of the following operating systems, it's OK to run Wise Toys:
  • Windows 10 (All Windows Editions, including both 32-bit and 64-bit)
  • Windows 8 (All Windows Editions, including both 32-bit and 64-bit)
  • Windows 7 (All Windows Editions, including both 32-bit and 64-bit)
  • Windows Vista (All Windows Editions, including both 32-bit and 64-bit)
Since Wise Toys is a small and quick program, it takes less memory and needs fewer hard drive requirements.
Wise Toys does not support Mac OS or Linux.
©2006-2021 WiseCleaner.com all right reserved,powered by GitbookEdited: 2021-07-06
