Code Converter
Code Converter is a plug-in that can provide a code generator. This is a great help to program developers and computer programmers. If the user needs one of these items, just generate and copy it directly in the plug-in. Currently, the plug-in contains date, GUID\UUID; Hash , Unicode, URL, Base64, Programmer, HTML Escape Characters, a total of eight modules.
1. Date
Including local time, timestamp (seconds), timestamp (milliseconds), Greenwich Mean Time.
The local time, timestamp (seconds) and timestamp (ms) can be modified in the middle part
2. GUID\UUID
The full name of UUID: Universally Unique Identifier, that is, universally unique identifier. It is a string generated by separating a 32-byte string with 4 hyphens (-), and a total of 36 bytes long. The Universally Unique Identifier (UUID) is an identifier standard used in software construction, standardized by the Open Software Foundation (OSF) as a part of the Distributed Computing Environment (DCE). Simply put, UUID is a standard. The term GUID usually refers to Microsoft's implementation of the Universally Unique Identifier (UUID) standard. It contains uppercase letters, lowercase letters, uppercase letters without-and lowercase letters without -. Click the generator button to automatically update the ID value. Click the copy button to copy the content.
3. Hash
Hash transforms an input of any length (also called a pre-image) into a fixed-length output through a hashing algorithm. The output is the hash value. Contains the following reference values: MD5, SHA224, SHA256, SHA384, SHA512.
4. Unicode
code point, UTF-8, UTF-16, \u{}, HTML(Dec), HTML(Hex)
5. URL
Supporting encode and decode mutual conversion.
6. Base64
7. Programmer
dec, hex, octal, bin, 32hex.
8. HTML Escape Characters
The following strings can be copied separately.
Double quotes "
And and & &
Less than < ⁢
Greater than sign > >
Non-breaking space
